Salta al contenuto principale
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Domande Visualizza tutte
Can I upgrade the ssd of the mba 2012
hi may i know for the latest mba2012 we can upgrade the 128gb ssd to 256 or 512 gb ssd ourselve? and how about the macbook pro retina 2012 for the same questions from 256gb to 512 gb ssd?
2. if yes then can u recommend what brand of ssd we should get and anything we need to take notice before we buy the ssd?
Thanks and best regards : )
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hey!
The MacBook Air and the MacBook Pro Retina both use custom connectors.
There have been fitting SSDs for older MacBook Airs around, but Apple changed the design of the connector with the 2012 model. You should also note that the SSDs of the MacBook Air and the MacBook Pro Retina are not interchangeable.
Chances are however good that there will be compatible drives for both machines in the coming months.
Long story short: Currently NO, in a few months PROBABLY YES.
Punteggio 4
2 Commenti:
Thanks senthor for ur good info!!!
da
Thanks, good info for me too.
da
OWC are now selling SSDs for the newest MBAs! Check out this link: http://eshop.macsales.com/shop/SSD/OWC/A....
If the link doesn't work, google OWC for more info. Hopefully, OWC can provide upgradeable SSDs for the MBPRs!!
Punteggio 4
Its a REPLACEMENT drive. There are external adapters/housing to use the SSD module that you remove as an external drive (super fast one). Probably worth it for a 128GB SSD class usb 3.0 external disk that fits in your pocket. OWC also makes that adapter (part of a kit too).
Punteggio 0
Aggiungi la tua risposta
lsgan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 43,248
