Salta al contenuto principale
Informazioni di riparazione e smontaggio per il mouse da gaming wireless Logitech G305. Identificabile dal numero di modello M-R0071. Rilasciato a maggio 2018.
Scroll wheel doesnt work properly
İt doesnt detects the rotations direction
For ex. İ am rotating it to front but it detects random imput. İt goes up and down constantly randomised when i move it
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
Hi! I am not super well versed when it comes to mice, but I hope the following may be a bit helping.
This issue can be cause by multiple problems. A few potential causes can be:
  • Dust or debris in the scroll wheel assembly. This would opening and cleaning the scroll wheel assembly. Using compressed air, a brush and/or electrical cleaner to get rid of debris and oxides.
  • The scroll wheel does not make proper contact with the scroll sensor. This could potentially be fix by re-assembling the scroll wheel assembly.
  • That the mouse scroll is worn out, or damaged. This would mean replacing the scroll wheel assembly.
I can not guarantee that either of these are the cause as there are a myriad of things that could cause you issue. Nor can I guarantee that either of these solutions will work.
Anyway, here is a guide on Come aprire il tuo mouse Logitech G305, and here is a guide on Sostituzione rotella di scorrimento del Logitech G305. Here is an older Q&A that might prove insightful: Left Mouse Button not working consistently..
Good luck,
Cheers
Immagine Logitech G Series Mouse Rotella di scorrimento
Guida
Difficoltà:
Moderato
10 - 20 minutes
Immagine Logitech G305
Guida
Difficoltà:
Moderato
20 - 30 minutes
Punteggio 1
Aggiungi la tua risposta
Muhammet Emin Çelik sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 41
Ultimi 30 giorni: 186
Tutti i Tempi: 1,372
