Why does the machine get stuck?
When i try to use it the needle gets stuck inside the bobbin case. The bobbin case doesn’t work and is stuck
Questa è una buona domanda?
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 48
Tutti i Tempi: 330
I cleaned out the bobbin case and have put everything back as the diagram and the top thread gets tangled and the needle won’t come up
=== Update (05/08/26) ===
How do I fix it
da Audrey Joyce Carre Condividi
@audreyjoyc49032 are you having the same problem with your sewing machine as the OP (Original Poster)? What make and model is your sewing machine?
da oldturkey03 Condividi
