Salta al contenuto principale
Rilasciato a luglio 2018, il MacBook Pro da 15", modello A1990, adotta uno schermo retroilluminato a LED da 15,4" con tecnologia True Tone, Touch ID e processore fino a esa-core Intel Core i9.
Topcase Replacement Issues - Wont display
Hi all,
I had to replace my top case on my 2018 MacBook Pro 15 inch (A1990). I worked through everything slowly and purposefully. When I tried to turn it on it wouldnt turn on. Then I connected the mains power adaptor and it fired up, I heard the chime but nothing on the display. The Touch Bar lit up and I could increase the volume and decrease but nothing else. Now I cant turn the unit off.
Can anyone shed any light on what might have gone wrong with the procedure or what I need to do to get it up and running again!
Many thanks
Questa è una buona domanda?
Punteggio 0
4 Commenti:
Why did you replace the top case? Do you mean the display lid part or the uppercase keyboard part?
da
It was the keyboard part DanJ
da
@mansoorahm23124 - OK, did you have a liquid spill of some sort?
da
No, some of the keys were missing so thought of replacing the keyboard. Unfortuantely, that meant replacing the topcase in its entirety!
da
Aggiungi un commento
1 Risposta
I would look at the guides and check that the LCD cable is connected and also the battery connection. IF still no improvement then prehaps @danj can give some more insight.
Punteggio 0
Aggiungi la tua risposta
Mansoor Ahmed sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 16
Tutti i Tempi: 178
