Salta al contenuto principale
L'Infinix Hot 10i è uno smartphone entry-level con schermo da 6,52 pollici e una batteria da 6000 mAh, rilasciato a maggio 2021.
My screen is broken
After I fell on top of a rock the screen crack
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@alfieping thanks to your description, this makes it easy. You have a broken display and you will have to replace the screen assembly. Since iFixit does not yet have a specific guide for this, use something like this video as your guide. Replacement screens are readily available and not to expensive. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 0
Aggiungi la tua risposta
Alfie Ping sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 119
