Salta al contenuto principale
A1708/EMC 3164 — Pubblicato a giugno 2017, questo MacBook Pro di fascia entry-level conserva i tradizionali tasti funzione (a differenza della Touch Bar OLED).
Why is MacBook Not Displaying Anything
Hi All
I have a very strange issue on the macbook
Issue is
Charger gets plugged in with am-meter and it shows 5V>20V and 1.5A on battery and approx 0.6A when the battery is disconnected.
PPBUS_G3H is present on F7000 on both sides and when in Ohms mode readings are expected
Nothing is shown on external monitor and caps lock key doesnt light up
The CPU gets very hot,.
Any advice please
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
You'll need to grab the schematics and board view drawings for the system to identify the parts that are getting hot. A good IR camera can make quick work of it or just drip a few drops of isopropyl alcohol onto the area, checking both sides.
Punteggio 0
Schematics can be found here & board view here.
You'll need FlexBV to view the board view file.
Punteggio 0
Aggiungi la tua risposta
Ali sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 11
Tutti i Tempi: 90
