Salta al contenuto principale
L'HP ProBook 640 G4, o HP ProBook 640 G4 Notebook, è un portatile lanciato per la prima volta nell'estate del 2018 come parte della quarta generazione di HP ProBook. L'HP ProBook 640 G4 è un portatile business di fascia media con uno schermo da 14 pollici.
Laptop screen is blinking
How to repair laptop screen blinking
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi!
Please try connecting an external monitor to your laptop. If the screen is appearing as normal, it is more likely to be a hardware failure of some kind, that the screen module is broken, loose or damaged cables etc., and the faulty component would need to be repaired or replaced.
If your problem appears on an external monitor too, it is more likely to be a software problem, it can be faulty driver or a GPU problem. Try making sure that you have all your firmware/drivers/BIOS up to date and try making a clean install of your GPU drivers. If your running windows 11 you can on-top of this also go to Settings > Windows Update > Advanced Options > Recovery and then select "Fix problems using Windows Update" by pressing Reinstall now.
Punteggio 0
Aggiungi la tua risposta
Bharti Aswani sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 117
