Light control are jammed
Cannot turn on the light the controls had jammed
Questa è una buona domanda?
Your Grand i10’s light control is likely stuck because of a failed or worn combination switch, though it could also be a blown fuse or a dirty switch mechanism. Try gentle movement + contact cleaner and check the headlamp fuse. If it’s still jammed, the stalk assembly needs replacement — a quick and inexpensive repair at most workshops.
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 15
Tutti i Tempi: 163
