Salta al contenuto principale
Cuffie da gaming cablate USB over-ear Redgear Cosmo 7.1 con microfono, audio surround virtuale, cacciavite da 50 mm, LED RGB e telecomando (nero)
Fixing broken head sets
My headset is not working I am not actually interested with the mic I'm mostly interested with the speakers. I need instructions on how to connect the wires from the in line control pod directly to the speakers
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Based on your post I take it that your headset cable is broken.
If the cable is broken by the headset, you may be able to get away with just shortening the cable, and re-soldering it inside the headset. Tho, make sure to take pictures and notes of which wire goes where. The wires used in headsets are usually very tiny and can be a bit tricky to solder.
Otherwise, you will have to open your headset and the controller pod, and note which cable goes where. Then you can de-solder the broken cable and solder on a new cable. Though, the solder pads on the circuit board can be a bit tricky to solder.
Punteggio 0
Aggiungi la tua risposta
Martin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 19
Ultimi 30 giorni: 38
Tutti i Tempi: 313
