Salta al contenuto principale
Guide di riparazione e informazioni sullo smontaggio del Surface Laptop di terza generazione di Microsoft, rilasciato nell'ottobre del 2019.
Can I replace the memory (Microsoft surface model: 1868)
is the memory in any variant of the 1868 Microsoft surface replaceable without soldering or even WITH soldering.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta piĂ¹ utile
Officially the answer is "NO" because they ARE soldered in place. Here is a link to a discussion on this topic, however, and it seems, Yes it is possible, perhaps one of the folks who does this sort of thing professionally can give a better answer, it seems there is more to it than just replacing the memory with the compatible puppies, though... the link:
https://www.reddit.com/r/Surface/comment...
Punteggio 1
1 Commento:
@zivameyer you will also need to update and flash the BIOS otherwise your computer will not boot up with a change in memory. The soldering of the memory module will require a proper rework station.
da
Aggiungi la tua risposta
ziva meyer sarĂ  eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 16
Tutti i Tempi: 166
