Salta al contenuto principale
Lo Xiaomi Redmi Note 10S è uno smartphone di fascia media prodotto da Xiaomi e rilasciato a marzo 2021. È dotato di un display elettronico AMOLED da 6,43", una fotocamera posteriore principale da 64 MP, un sensore di impronte digitali montato lateralmente, una batteria da 5000 mAh e funziona con un processore Mediatek Helio G95.
Display does not respond correctly to touch
More than two weeks ago, my father had his display replaced because his phone fell and broke the display, but since they replaced the display, he went back to the service centre because the display does not respond correctly to commands. Sometimes it does its own thing. I thought it was a dirty display, but cleaning it does not solve the problem.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@piero90 that sounds very much like a bad touchscreen/LCD assembly. Since this happened right form the beginning I would strongly suggest that your dad has the service center replace it once more with a proper replacement. This will not get better on it's own, there are no calibrations or adjustments.
Punteggio 0
5 Commenti:
My father went to a service centre twice.
da
@piero90 they did replace the screen already?
da
@piero90 sorry to hear this, but something like "Sometimes it does its own thing." is pretty much a sign of a bad display assembly. Let's see if there are other answers that come up with a different idea.
da
My father went to the service centre for the third time to have the display replaced, but the problem persists, so I assume it is a logic board issue.
da
Aggiungi la tua risposta
Piero Sabino sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 21
Tutti i Tempi: 240
