Salta al contenuto principale
Informazioni e guide di riparazione per il MacBook Retina 12" 2015 modello A1534
LCD or GPU Issue?
I have here an A1534 1.1 GHz model that has suffered the all to common CPU failure from I guess overheating, which must be common in these fanless Macbooks.... And someone is offering me the same model (But not sure the CPU as 3 versions were made) for next to nothing price, but it comes with this apparent display issue....
Immagine
Immagine
Immagine
I am thinking to just swap over the logic board to make a 'working' unit, but I am concerned that there maybe an irreparable GPU issue other than a faulty display..... to me it looks reminiscent of the scenario when changing the default resolution and then rebooting where these similar lines appear for a split second until the system recognizes the adjusted resolution which to me points to a GPU error as the lines remain as pictured when the system is active.
Questa è una buona domanda?
Punteggio 1
2 Commenti
it may be a gpu issue on your macbook or some componants going to the gpu got knocked off
da Condividi
Can you try it with an external monitor? That should tell you whether it's a GPU or display issue.
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
I'm not a MAC person, but the display appears to be functioning and the computer is having a problem. Therefore, my guess would be that the computer can't load the drivers to the GPU and isn't getting a response from the GPU. Therefore, it is likely a GPU issue. If it isn't a plug in part, the MB needs replacing.
Punteggio 0
1 Commento:
Yeah these are nice looking MacBooks but TOTALLY useless and prone to MB Issues..... Just a nice ornament.
da Condividi
Aggiungi la tua risposta
livfe sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 31
Tutti i Tempi: 255
