LT gets pressed and slowly releasing
My coworker tried installing an ExtremeRate clicky trigger kit after I did mine, but he ran into issues and asked me to fix it. Right now, the controller only works when the trigger is adjusted to the shortest throw, where the clicky switch actually engages, but it's really slow to release. It looks like he may have overheated the joystick area while soldering, though I'm not certain if that would affect the triggers. I removed all his solder, replaced the damaged ribbon cable, and reinstalled a new clicky kit, but the issue remains.
Update (11/03/25)
So I circle where you solder on the right side you solder to the right side of that little diod guy idk what ya call it and the one on the left side you solder to the bottom what he ended up doing on the left side diod guy was fill both sides together he did also get the joystick pretty hot and melted it some
Questa è una buona domanda?
Punteggio 1
10 Commenti:
Hi!
Can you share any pictures with us regarding the solder work and the triggers?
Aggiungere immagini ad una domanda
Thank you!
da
Yea I can when I get off work today
da
That is fine! Thank you!
da
Hmm, the picture is somewhat blurry! I cannot zoom in.
Please check the traces, are they fine? Did you tried replacing the sticks again?
Thanks!
da
The sticks do still work but the left trigger is out dose the left trigger have anything to do with the trigger?
da
Mostra altri 5 commenti
Aggiungi un commento
