Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
20 Domande Visualizza tutte
Which replacement display should I get?
MacBook Core 2 Duo from 2011
Serial: 45112DAUF5W
- My MacBook is the one that is rounder on the edges than previous laptops in the MacBook line. It is the one with an all-white fingerprint-resistant glossy palm rest, unlike the grayish surface of its predecessor, and uses a multi-touch glass trackpad. The bottom of the MacBook has a rubberized non-slip finish.
The display is damaged.
Which replacement display should i buy?
Which MacBook is the Unibody? Mine?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here how todo: MacBook Core 2 Duo LCD Panel Replacement
U deside.
Punteggio 2
Thanks for the info.
One question:
What is the MacBook Unibody?
I was going to order the LCD but it said: All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
Is my MacBook a unibody? MacBook Core 2 Duo from 2011?
MacBook 13.3" LCD Panel
Immagine Replace an LCD Panel compatible with the 13.3" MacBook laptop. 1280 x 800 pixel Resolution.
Prodotto
$49.99
Punteggio 0
2 Commenti:
According to your serial number this is your computer. And yes it is a Unibody.
http://everymac.com/systems/apple/macboo...
da
So my question: Which replacement LCD Panel should I get for my MacBook 13" Unibody?
On the previous link "MacBook 13.3" LCD Panel available at 149.95" it says: Compatibility: All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air).
Thanks
da
Aggiungi la tua risposta
Rune sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,245
