Salta al contenuto principale
Water Pump Constantly running
I have a problem with my delonghi coffee machine. the water pump is constantly running with the water going to overflow tray. As soon as I plug the machine to power socket the water pump starts running (even if machine is turned off). What can be the solution please?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@victor17222 Which model ist it? ETAM ???? I think its an issue with the motherboard, perhaps it must be replaced.
Punteggio 1
2 Commenti:
It is Etam cappuccino Eletta, so pcb board then?
da
@victor17222 Look at the type plate: it should look something like this ETAM 29.666 or ETAM 36.366. There are essentially two different circuit boards, but you need to know the exact part number, printed on a sticker. Both cost around €65. Or try to have it repaired; there is a special workshop.
da
Aggiungi la tua risposta
victor sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 20
Tutti i Tempi: 201
