Salta al contenuto principale
La prima Legacy fu disponibile presso le concessionarie giapponesi il 1° febbraio 1989, con una distribuzione globale iniziata nel 1990.
Seized Left Rear Wheel
my L/R wheel is seized,is it the rear hub unit bearing?
Questa è una buona domanda?
Punteggio -1
7 Commenti
What is your definition of "seized"? what does it do and what does it not do? Did this just start? What type of transmission does it have?
da
wheel will not engage forward or reverse,just happened,auto transmittion
da
is it FWD or AWD?
da
Its All Wheel Drive
da
Same thing, check the brakes, see if you can release the brakes and if your wheel will turn. Possible seized bearing or seized rear differential :(
da
Mostra 2 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
Donna, if it is a FWD model, it is possible that your hub has seized up. Of course, the only way to really determine this is to, jack up the car, remove the wheel, and remove the rear brake. Possibly that your break is causing this too. Check to make sure that the brake shoes from the parking brake are properly releasing, and the the brake caliper is not seized.
Immagine
Immagine
Punteggio 2
Aggiungi la tua risposta
Donna sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 16
Tutti i Tempi: 1,564
