Salta al contenuto principale
Informazioni su riparazione, smontaggio e risoluzione dei problemi per iPhone 16, lanciato il 20 settembre 2024. È dotato di un display OLED da 6,1", un sistema a doppia fotocamera da 48 MP e una porta USB-C. Successore di iPhone 15.
Upgrading iPhone 16 Logic Board
Hey Guys,
So i have a iPhone 16 128GB and i want to upgrade to a 512GB Logic board. Do any of you know where i can find a iPhone 16 512GB Logic Board?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Hello.I'll tell you how to upgrade this iPhone 16 right away.
①AliExpress: If you search for keywords such as "iPhone 16 512GB logic board" or "iPhone 16 512GB mainboard", you can confirm the operation from overseas suppliers You can find a completed (but usually unofficial) logic board.
②eBay: In the same way, things that work and items for repair parts are listed by individuals and contractors.
You can get it using the above method. This is the end. From gkps.
Punteggio 0
If you don’t want to deal with parts pairing issues, you can always solder a new SSD chip onto it, it’s pretty extensive work, but it’s doable. Apple completely removed the SSD chip pairing limitations on iPhone 13 and above.
Example:
https://youtu.be/1WaxjRJmghc?si=jXId-NE4...
Punteggio -1
Aggiungi la tua risposta
Elias_Samuel sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 34
Tutti i Tempi: 640
