Salta al contenuto principale
The Olympus OM-1 was released in 1972 as a revolutionary 35mm SLR, offering a professional-grade, fully mechanical system in a body significantly smaller and lighter than the competition. It featured a bright viewfinder and unique controls, such as the shutter speed dial located around the lens mount rather than on the top plate.
Maintenance question for OM-1N
I picked up a near mint OM1n from ebay, and i really want to keep it in mint working condition but where i live (island nation) there are quite literally zero shops that specialize in vintage repair/maintenance cameras, let alone Olympus systems. And i dont feel like sending it overseas.
My question is basically this, is there any guide/video tutorial out there that shows and explains a complete CLA process for the OM1 or similar cameras? Im aware im no technician but i can follow specific instructions on my own risk, specifically what kind of lubricants/grease to use, when & on which parts, how to disassemble exactly whats needed and put everything back together. I tried youtube but it doesnt go much further than light seal replacements and prism foam cleaning.
Basically the most basic maintenance a professional would do to prolong the life of the camera.
Or at least as much as a regular person with normal precision tools can perform at home.
Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
You can find the repair manual for your camera online as a PDF from a few sources. Scan example here's the older version Olympus OM-1 service manual here's the rest of the manual grab the last one gets into lube OM-1 & OM-4 maunals
Punteggio 2
3 Commenti:
now where is a copy for the OM2n ?
da
@om1gc - The mechanicals are the same across the OM-1 series. Only the metering and flash circuits are a bit different.
da
@om1gc see if the manuals on here Olympus OM-2 under the documents tab will work for you.
da
Aggiungi la tua risposta
DBCooper sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 12
Ultimi 30 giorni: 48
Tutti i Tempi: 716
