Salta al contenuto principale
Windows 11 presenta un'interfaccia utente completamente nuova, che include una nuova barra delle applicazioni, nuove icone centrate, trasparenza delle finestre, angoli arrotondati e un Microsoft Store aggiornato.
iPhone Errors. Help / Bugg? / Drivers?
Helloe.
I have some problems with my Windows 11. I only get Errrors when i try to uppdate or Restore my iphones. Is it some drivers or some other things i need to do. To get it work in Windows 11. Worked just fine when i had Windows 10. But something is realy wrong in my Windows 11 Pro.
/ Markus
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Depending on which version of iTunes you have I have seen the Microsoft Store version fail - Apple pushes it (even internally, by procedure) but it's a bratty piece of software. Get it from the website: https://www.apple.com/itunes/
Click Looking for other versions?>Windows. That one works.
If it persists, stop and check the cable - it's usually that; and 3 strikes means lost encryption key and complete data loss unless a restart saves you (not consistent). The problem is Lighting phones are a known issue here due to the way they fail - silently. It will charge your phone, but it will have issues on the data lines. The other thing I see cause issues is adapters, which cause issues with Lightning. It's rare but sometimes bad ports do it -- ask me how I know from my Dell E6540 and 6440 which were notorious for losing the USB port on the VGA side to failure. USB-C iPhones seem fine, but they're also not aged yet to the point of knowing how robust the cable is. That said my 15 Pro cable is still good nearly 2 years later - so they might have built them to not fail within a year.
Buy a NIB cable from Walmart, Best Buy or your local Apple store, and try again. Brand new cable matched to your ports tends to fix it every time.
Take a look at your PC and see what you need. Rectangle is USB-A (Apple speak for USB), rounded means USB-C (Apple puts USB-C on the box here).
Immagine
Punteggio 1
7 Commenti:
i have tried 7 Different USB port och my computer. And my USB-C Port. i only get to 50% when i try to uppdate on all 4 iphones i have. And get Code 53. And when i try to Restore i only get code 1109. And every one says Apple Devices dont work for dhem eiter on pc. Its like Apple have put som sh-t in the app so it only will work with mac.
da
And What is NCM DATA?
da
@markooz86 1109 seems to be an ISP issue. I would see if you can do it over Ethernet if your machine supports it. Error 53 is a home button error.
da
@nick i have 500 mbits internet. directly in to only 1 computer. And home button dosnt even exist on a iphone 11 pro =D
da
@markooz86 Making sure given Error 53 has a history.
da
Mostra 2 altri commenti
Aggiungi la tua risposta
Markus sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 16
Ultimi 30 giorni: 35
Tutti i Tempi: 355
