Salta al contenuto principale
Lo ZOYI ZT-703S integra le funzionalità di un oscilloscopio, un generatore di segnale e un multimetro, offrendo uno strumento poliedrico per svariate applicazioni.
Multimeter function is not working
Hello. I have a ZT-703S with a problem: the oscilloscope function works fine, all buttons work, and it takes measurements normally. However, when I switch to the multimeter function, only a few windows appear, including the analog scale, but no numbers appear. It no longer responds to functions like diode, resistance, and voltage. I updated the firmware and reset the settings to factory settings, but it still hasn't returned to normal. Does anyone know how to fix this?
Questa è una buona domanda?
Punteggio 0
4 Commenti:
Hi @brunogouve48763
had you checked the internal fuse?
da Condividi
Yes, I checked the fuses, they are ok. I haven't found the solution yet.
da Condividi
Isn't the issue in below Youtube video a similar issue as what you have?
https://www.youtube.com/watch?v=P6QntvNA...
He was a able to fix it by re-soldering the chip.
da Condividi
Hello!
Yes, the same problem as in the video.
However, I resoldered the component as instructed in the video, and it didn't work. When measuring with an oscilloscope, there are frequencies in the transformer's primary and secondary. But it still doesn't work.
da Condividi
Aggiungi un commento
1 Risposta
Ah OK, sorry to hear it didn't work for you.
Sorry that I can't be of more help.
Hopefully there are others who can.
Good luck!
Punteggio 0
Aggiungi la tua risposta
Bruno Gouvea de Paula sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 52
Tutti i Tempi: 509
