Salta al contenuto principale
Guide di riparazione, smontaggio e informazioni sulla risoluzione problemi per la terza generazione del controller Sony PlayStation 5 DualSense. Identificabile dal numero di modello CFI-ZCT1W e dal modello di scheda madre BDM-030.
Audio jack not working
The audio jack was working fine until yesterday but today when fired up my console my wired JBL headphones wont connect. I tried with other controller and they seemed to work fine so not a headphone issue definitely a controller one... anyone know how to fix this?
Questa è una buona domanda?
Punteggio 1
3 Commenti
Hi Sam!
Is the Dualsense it's firmware up to date? Just in case!
Do you use the controller on the PS5 or PC?
Do other headsets work or airpods or whatever?
Thanks!
da
I use it with ps5 and yeah firmware is up to date👍
da
Okay! That’s good! Do you have any other headset to test?? This would be the ultimate test.
In the worst case, you do need to replace the headphone jack.. this requires soldering and soldering experience!
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hey,
This is a common issue with PS5 controllers, I've attached a YouTube link for a couple quick diagnosis methods. Unfortunately if none of these methods get your controllers audio jack working again you may have to replace the audio jack which will require you to disassemble the controller and do some soldering.
Here is the YouTube link.
https://youtu.be/0goVWJZ_Ozo?si=A6N_OHSO...
Hopefully this helps, best of luck!
Punteggio 1
3 Commenti:
Thanks so much man cleaned it with alcohol issue resolved 👍👍
da
All good, glad you got it sorted.
da
Glad that it is working! Have fun gaming again!
da
Aggiungi la tua risposta
Sam Medadkar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 81
Ultimi 30 giorni: 332
Tutti i Tempi: 4,250
