Salta al contenuto principale
Informazioni di riparazione per la serie di portatili HP 600.
My laptop won't charge
I have two HP laptops. One of them won't charge using the same charger. If I charge the battery on the first one and place it in the second laptop work fine. I disassembled it and checked for the DC power jack, and it worked perfectly. Any ideas about what could be the problem?
Questa è una buona domanda?
Punteggio 0
4 Commenti
Have you tested that the battery of the non-charging laptop works? If not, try putting that battery in the laptop that won't charge and see if you get the same issue.
da
@havynkrentz battery works perfectly. I guess there's some problem in the motherboard. Everything works as it should, except it won't charge.
da
@anwar29099
What is the full model number of the laptop that doesn't charge?
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @anwar29099
Here are the motherboard schematics that should help.
Go to p.8 and following the DCIN path from pin 1 of the DC-IN cable connector on the motherboard to see how far you get. Also check that the circuits connected to the other pins i.e. 3,4 &5 are also OK
Punteggio 1
Aggiungi la tua risposta
Anwar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 17
Tutti i Tempi: 141
