Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento:
Have you verified the power supply is working? You should see 19.5 volts coming out from the plug. If you don't have a voltmeter, you may need to try the supply with a different device or try a different charger.
da Jerry Wheeler Condividi
