Salta al contenuto principale
Informazioni per la riparazione e lo smontaggio dell'eReader Clara BW (bianco e nero) di Rakuten Kobo, lanciato ad aprile 2024. Identificato dai numeri di modello N365, N365B o P365.
Backlight not always working
My Kobo is a Clara HD, and for several months now I'm experiencing some issues with the backlight. I'm not sure if it's something hardware that can be fixed or if it's software.
Whenever I recharge my kobo, the backlight will stop working for a period of time that can range from a few hours to several days.
I've done quite a few tests to try to troubleshoot the problem with no success.
The level of battery does not seem to be directly connected as I encounter the problem no matter if I recharge when the battery is low or high and how long I recharge for.
Factory reset will always instantly fix the problem.
I would really appreciate any insight.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta piĂ¹ utile
If Factory reset always fixes it, that seems like a software issue to me. I was going on a tear about battery charging and thermal expansion. But then I saw that a factory reset fixes it, so that seems more software related, even if it comes back.
Have you made sure you have done all software updates?
Punteggio 1
1 Commento:
Yes, the software and firmware are up-to-date. The only thing I didn't try yet is a downgrade, I might consider that and see if temporarily fixes it.
I'm afraid it's a mix of hw and sw issue.
da
Aggiungi la tua risposta
Federica sarĂ  eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 16
Ultimi 30 giorni: 46
Tutti i Tempi: 523
