Salta al contenuto principale
Il PowerMac G5 è un computer desktop prodotto per la prima volta nel 2003 dalla Apple Corporation. Questa guida esaminerà il processo di riparazione di un Apple PowerMac G5, numero di modello A1047 EMC 2061 del 2004. È stato fuori produzione dal 2006 come parte del passaggio a Intel, prima per gli sviluppatori e poi per i consumatori.
Help Identifying a Part from a G5 PowerMac
I'm currently reassembling a 2005 G5 2.0 GHz DP, M9747LL/A.
I have the following part but I can't remember where it came from, and I've not documented it in my photos I took during disassembly.
Can anyone help identify it?
Thanks.
Immagine
Immagine
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
2 Commenti
What did you do? That might offer a hint where to look.
da
I did a complete teardown as it was the most filthiest computer I've ever come across.
It was likely removed after the motherboard came out. Maybe somewhere around the HDD holders.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
It's been quite awhile since I've worked on these older systems I keep thinking it's a logic board stand off holding the board off of the side panel (bottom side of logic board). Just behind the PCI slots you should see some holes where the pins and latch tab pass through to secure it.
Punteggio 0
2 Commenti:
I've added two more photos, do you mean in that area?
I realise it's a bit vague, and it is my own fault for not paying enough attention when taking it apart. But I do appreciate everyone's input on this.
da
Found it, it covers a cable on the lower left of the board near the RAM slots.
da
Aggiungi la tua risposta
David sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 14
Tutti i Tempi: 180
