Salta al contenuto principale
Guida di riparazione, smontaggio e informazioni sulla soluzione problemi per il mouse wireless Logitech MX Master 3S. Rilasciato nel 2022 e identificato dal numero di modello MR0077.
The device is un-responsive
The device become unresponsive without any pre failure notice, I have disassembled it for further check and reading is as follow
The battery charge is 4.1V
When cable is connected the battery slot shows 4.5V with the battery discounted
Even though no singe led shows sign of life, and no connection or status on the back side shows sign of connection
Any suggestions to repair
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
I've got same problem
I am able to see the IR light working but not any sign of life either
Immagine
I've contacted Logitech Support, the only thing they can give is a 20% coupon...
My mice is not under warranty, bought mid-2023, died Q1 2026
With all the respect, it's pretty shameful, a perfectly working mice dying suddenly like this..
Please help us !
Punteggio 0
1 Commento:
i just read another post that indicated the 3s has a known MB issue - which I didnt know about. If nothing works, that may be the problem.
da
Aggiungi la tua risposta
Ali Salah sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 20
Tutti i Tempi: 209
