Salta al contenuto principale
Monitor LCD in alluminio da 20, 23 e 30 pollici introdotti da Apple nel giugno 2004. Modelli rispettivamente A1081, A1082 e A1083.
Large Yellow Bar Running Vertically
I purchased this display used, and I haven't had any problems with it until recently. A thick, faint yellow line has been showing up vertically through my screen. Restarting and unplugging hasn't worked. After it's been on a while, sometimes it will disappear, but lately—it's been staying all work day. Does anyone know what's causing this? Photos below!
Immagine
Photo #1: Screen with yellow line issue.
Immagine
Photo #2: Original cord has electrical tape on wire. (I bought it like this.)
THANKS!
Questa è una buona domanda?
Punteggio 1
5 Commenti
Howdy there, has the display been moved in a way that could have damaged it? Also is this the display the 27" model that only have the thunberbolt and magsafe connector shown here?
da
@jmehnert - These are the older DVI connection and you need a DVI to mDP port or Thunderbolt port adapter.
da
@jmehnert Hey! Thanks for your reply! Yes, it's the 27" model. Your link took me to the main "repair" area—I didn't see a specific magsafe connector image to compare the two!
da
@danj I'm not sure I follow. I have my Thunderbolt connected to my computer using this adapter: https://www.apple.com/shop/product/MYH93... It's been fine until now the yellow bar is showing up.
da
@reneeswigert - This is the older DVI model, yours is a TB2 with a TB3 adapter for your systems USB-C connection. As it turns out the TB3 interface offers multiple services old USB, mDP and USB-C based as well TB!
da
Aggiungi un commento
1 Risposta
Risposta più utile
This is a kind of TAB error when the LCD glass and the flex cable are bonded together a connection can get broken which in this case causes the yellow bar. Sometimes massaging the interface can get it reconnected. But that will require a bit of disassembly to gain access to the back of the LCD panel.
While the cord is cracked which is likely why it's taped, you might be able to locate a replacement cable.
Punteggio 1
2 Commenti:
Thanks for the insight! I'm pretty handy (as long as it doesn't involve soldering!), and I don't mind opening it up per the ifixit instructions I saw. I picked this monitor up for $150, so I don't have that much into it. Can't hurt to try!
da
Hi Renee, have you fixed the yellow lines? I'm having the same issue with my Thunderbolt Display
da
Aggiungi la tua risposta
Renee sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 28
Tutti i Tempi: 385
