Salta al contenuto principale
Laptop Lenovo rilasciato nel 2019, numero di modello 81LW000QSB.
Does it support eGPU?
So i know that the Lenovo L340-15API 81W has an M.2 ssd slot that supports NVMe. but if i connect a real GPU with an adapter to the M.2 slot can i actually use it with a monitor? If someone actually tried this for some reason pls give an answer(i dont wanna waste money)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If it has an M.2 slot, and you have an adapter, you can indeed plug in an eGPU
But, there are some downsides
1 - The laptop likely won't be possible to close back up again
2 - You will likely need to reinstall windows afterwards
3 - It's very costly
If it was a desktop, I would go for it, but this is a laptop so I'd rather not sacrifice it's... laptop-ness
Punteggio 0
Aggiungi la tua risposta
Ferenc sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 189
