Salta al contenuto principale
Il Ninja Foodi SP101 è una friggitrice ad aria digitale che funziona come friggitrice ad aria, tostapane e forno a convezione.
How to Remove Side Panel?
I have been struggling to get the side panel on this removed. I am aware the guide here says to unscrew the 3 screws and then push the panel towards the control panel until the clips are visibly detached
However I have not been able to produce this result with varying levels of force. There is something towards the control panel that is firmly holding that side of the panel in place no matter what I try.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
It works with light force, so there's probably still a hidden screw that needs removal. For me, it was the TR10 (security Torx) on the inside left front wall middle near the door, covered in grease. So in total you remove the black plastic bar screws, the back panel screws on the side you want to remove, and the screws underneath the bottom flip tray on the side you want to remove.
Punteggio 0
Aggiungi la tua risposta
Luke Davis sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 23
Ultimi 30 giorni: 63
Tutti i Tempi: 343
