Salta al contenuto principale
Guide di riparazione e supporto per le moto prodotte da Yamaha Motor Company.
solenloid decompression problem. Solved!
Road Star XV 1700 2006, solenloid pushes the two rods in, but valve does not stay open to decompress. Anyone an idea ? Cheers. Two days later : After opening up the crank-carterI, I found one of the two rod- levers was slightly bent, so it didn't push in the decompression-rod enough to engage the extra crank-opening-moment of the exhaust-valve.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
So if changing the starter-motor, start-relay and decompression-solenoid don't resolve the problem, take out the engine oil, then take of the crank-carter and check if the two rod-levers push both rods in ( equally ).
Punteggio 0
Aggiungi la tua risposta
kees van schaik sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 33
Tutti i Tempi: 373
