Salta al contenuto principale
Presentata al Salone dell'automobile di New York del 2004, la Xterra è stata riprogettata per il 2005 sulla piattaforma Nissan F-Alpha utilizzata dalla Frontier, entrando negli showroom nell'aprile 2004 per l'anno modello 2005.
Abs vds lights on dash
How do I get the abs vds lights on dash off
Questa è una buona domanda?
Punteggio 0
1 Commento
There are significant differences between the two generations of Xterra covered by the category your question is posted in, so it's important for us to know what year yours is. Engine size and transmission type would be helpful as well.
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
Without more information as I mentioned in my comment, it's hard to be specific, but in general it appears there's a fair chance one of your wheel speed sensors is having issues. Either a sensor has failed, a tone ring has come loose, or perhaps there is damage to the wiring. Being located on the wheels, those sensors are exposed to harsh elements on the road and are susceptible to damage.
Have you scanned the OBD-II port for any diagnostic trouble codes? Those should point you in the right direction to help diagnose the issue. I don't know where in the world you're located, but here in the US most auto parts stores will scan your engine computer for free. Once you have the code(s), come on back and edit your question to add that information.
Punteggio 2
2 Commenti:
Im in Pennsylvania I tried doing auto parts and they can't pull anything but I will look at what u said and see
da Condividi
@jamesbeavers Yeah, unfortunately many cars have the ABS system separate from the engine computer such that a standard OBD-II reader can't see the data; it has to be one made to work with your car. Most professional mechanics will have one, but they'll almost certainly charge you something to scan your ABS system. Of course a Nissan dealer should be able to tell exactly what the problem is with their equipment - for a healthy price.
da Condividi
Aggiungi la tua risposta
James Beavers sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 18
Tutti i Tempi: 216
