Salta al contenuto principale
How to clean speaker
Questa è una buona domanda?
Punteggio 12
Aggiungi un commento
8 Risposte
Risposta più utile
This generally works if the speaker sound is very low but you can hear it. If you can't hear anything then you might need a speaker replacement but it wouldn't hurt to check to see if its cleaned.
The way I clean phone speakers is with a toothbrush, isopropyl 99% alcohol and compressed air.
  1. Look at speaker to see if you can see anything blocking it
  2. Take dry toothbrush and brush the speakers using a little pressure but not much (you may see stuff come out keep going for like a minute)
  3. Puff the speaker area lightly with some compressed air
  4. Test call to see if sound improved
  5. If not, Put a couple drops of isopropyl alcohol on to toothbrush and complete step 2 and 3 again.
  6. Test call to see if sound improved
  7. If not, put could of drops of isopropyl alcohol into speaker area and plus a medium stream of air into speaker area not to powerful, then follow up with one minute of brushing.
  8. Test call to see id sound has improved
  9. If following this doesn'twork then more than likely you need a speaker replacement.
Punteggio 1
Spker cleen this
Punteggio 1
Ho my best wishes
Punteggio 1
In my realme phone mic can't work properly when I was calling with another one voice can't hear and not going to another person
Punteggio 1
1 Commento:
لا يعمل الميكرفون بشكل صحيح ولا استطيع سماع الطرف الاخر
da Condividi
Its not working proper sound of my phone
Punteggio 0
How to clean the speaker
Punteggio 0
Realme narzo 60 display repair
Punteggio 0
How I can clean my phone speaker
Punteggio 0
Aggiungi la tua risposta
Girraj Goyal sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 20
Ultimi 30 giorni: 76
Tutti i Tempi: 5,618
