Salta al contenuto principale
Modello A1502 / processore dual-core Intel Core i7 2,6 GHz (Turbo Boost fino a 3,1 GHz) o 2,8 GHz (Turbo Boost fino a 3,3 GHz) con 4 MB di cache L3 condivisa.
Fix keybord cable before replacement
I need to replace the keyboard of my MBP because sone key stopper working and I think it’s because the connector is damnaged. Before proceed, I’ve searched here some similar questions and found also one where there is an attacched video with the needed steps. I’m looking for a written guide I can follow, but my question is, can I fix only the connector instead of replacing the whole keyboard? To do the fix I need to remote the battery and display or I can avoid? If I Remo e the battery how I will put it in place again, is there a special take I can found on Amazon that I can use?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
I have made written guides for many models but ifixit has yet to approve them.
Sostituzione tastiera MacBook Pro 13" Retina Display inizio 2015
You'll have to remove the battery to change the keyboard, as the keyboards cable is part of the keyboard, and also to get to the track pad and it's cable, I would check this cable 1st as it is replaceable, check to re connect it 1st. and also any think double sided tape should be strong enough to hold the battery in its place again afterwards.
Punteggio 2
2 Commenti:
The 2015 model have sone differences with the mid2014?
da
@ziobru The exact guide for the 2014 model has yet to be published by ifixit. It is the virtually same procedure anyway.
da
Aggiungi la tua risposta
B1P sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 15
Tutti i Tempi: 286
