Salta al contenuto principale
Resistente all'acqua, uscita ottobre 2021
Screen white and light flashing
Hi, I tried to upload a file with Calibre and the Libra 2 stopped working. I tried to reset it, but screen became white and flash began lightening. Now I can turn it on and off, but basically nothing happens, but screen is white and light is flashing. When plugged, PC recognized something but is not able to identify the device. Any idea? Thanks.
Questa è una buona domanda?
Punteggio 4
4 Commenti:
ik heb dit probleem ook, al een oplossing bekend?
da
Same here. Restart doesnt work, hard reboot / reset either. it just keeps white screen and flashing led
da
I've got the same issue, other than that when plugging the reader into my pc, it doesn't even recognize it as a thing. I've got the SD card out of the thing, and the card itself is being recognized, but there are a couple of partitions that Windows isn't recognizing, potentially those are corrupted? Anybody have a good image for the OS?
da
Ever find a fix to this?
da
Aggiungi un commento
1 Risposta
Hello friends! I had this exact same issue and have since done a full repair on my device. The problem is that the Libra boot sequence fails once the update fails, this makes it impossible to boot or even charge. I will do my best to give a detailed walk-through here and outline the couple conditions that arose for me.
I highly recommend finding an SD card adapter, gathering your tools, and requesting an image from the MobileRead forums before starting the repair. Not a big deal to open it up first but it did take a couple weeks since I kept halting my progress at every step of the way due to being unprepared. If you're wondering about the tools or the forum read the guide below and you should see what you need.
The first thing to do is take apart the Libra 2. I initially got into the back of my case by using a guitar pick to carefully pry up the edges until the case came free. Any thin plastic shim will work.
Immagine
Once open there are three main sections: the battery, the main board, and the power switch.
Immagine
Immagine
Uninstalling the microSD card:
Immagine
If you're having a hard time getting the card out there are a couple tiny openings on the back that you can try gently but firmly applying pressure to. I'm pretty sure I punctured the back of my old SD doing this and killed it that way, so proceed at your own risk.
Immagine
Then go to this thread and request an image for the Kobo model. In my case I have a Libra N418 which can be found as the first few digits of your serial number.
Immagine
Once a helpful user sends you the files via PM there will be multiple board revisions and you will have to select yours. I have 6F0 also known as rev F. You can see that on the board here as the last 3 values:
Immagine
I then downloaded that file ("Kobo_Libra....rev_F.img") and used Terminal (MacOS) to copy the microSD card image over to the corrupted card. This will overwrite all data on the corrupted card.
But wait! The file that comes from said helpful user will have an incomplete serial number. You can choose to proceed anyways and your e-reader will be bootable but unable to connect to the network in anyway, including the Kobo Store and Libby/OverDrive.
Immagine
I wanted to connect to my library so I had to fix this using a hex editor. I chose to download ImHex because it seemed user friendly and I had never done anything with hex before. It worked great, I am sure you can find other tools that work just as well.
The serial number is located at 0x200. My image was set to N418xxxxxxxxx and I manually changed those x's to my own serial. Save the .img in it's corrected state and copy the file to your sd card.
If this doesn't work or the data seems unchanged that is because of one of two things. Either the sd card adapter is stuck on "read only" indicated by the switch here:
READ ONLY
Immagine
WRITE
Immagine
Otherwise, as with my card, it is physically failing and you have to use a new card, which works just as well.
At this point your sd card is back in a bootable state. When you first turn it on it may have issues connecting to the internet. I fixed that by updating the e-reader and then factory resetting it through Settings -> Device information -> Factory reset your eReader. This returned full functionality to my Libra 2.
Yay! Congrats! If you've made it this far you've helped saved another device from the e-waste bin. This was really tough for me to figure out my first go so I hope this level of detail helps others.
Punteggio 0
9 Commenti:
Hi There - I am not IT literate, can you please help me with the following;
1. I have downloaded the images from MobileForum. It comes as a compressed file and I have clicked "extract all" and the file has appeared in my said location ('Documents')
2. what do you mean by "The serial number is located at 0x200".
da
Hey Cosmic! This has been a few weeks so I hope you have your solutions by now but just in case I will answer both.
1. Once you have extracted all from the compressed file you should have "Kobo_N418_Libra2_6F0_rev_F.img". The ending .img is the most important part. This is a "disk image" which is essentially a snapshot of a storage device, in our case the Libra 2 microSD card in a healthy state.
You will take that .img file and overwrite everything on your corrupt Libra 2 microSD card. You can do that by using a terminal or downloading a disk image tool. I would recommend googling "How to a Write Disk Image from a file in (Win/MacOS/Linux)."
da
2. Hard drives store information in various "locations" on the hard drive. These are chunks of data storage and when your device wants some information it goes to that location and pulls what it needs. With a hex editor (a downloaded tool) you can see those locations and they'll translate that hexadecimal code into something legible to our human eyes.
Our Libra 2 stores the serial number for the device in location 0x200. If you go to that location you will see an incomplete serial number that you can replace with your own serial number. I will take some additional screenshots to flesh out my guide when I get a chance. I'm sorry this came so late but I hope these two answers help you or others who come after.
da
Did you have your SN written down before? I found a fresh image to flash but I'm having trouble locating my original SN, as I can neither boot my device nor did I have the foresight to write it down somewhere beforehand.
Right now I have my SD that won't boot but I can't figure out how to save it as an .img to check it with the hex editor, and I can't think of a way to find my serial number elsewhere.
da
Just had similar issue. I was a bit lucky as I was able to remove the old SD card clone it to a new SD card using the dd commande line utility. After booting from the new SD card I performed a manual/factory reset. That seem to have gotten rid of corrupt data, and restored the device to a good state once again.
da
Mostra 4 altri commenti
Aggiungi la tua risposta
Andrea sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 80
Ultimi 30 giorni: 358
Tutti i Tempi: 1,154
