Salta al contenuto principale
Cosa c'è dentro un chip? Come funziona? I chip per computer sono anche chiamati circuiti integrati, circuiti integrati monolitici, IC, chip o microchip.
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
Immagine
Questa è una buona domanda?
Punteggio 1
3 Commenti:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
da Condividi
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
da Condividi
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
da Condividi
Aggiungi un commento
1 Risposta
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
Punteggio 0
1 Commento:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
da Condividi
Aggiungi la tua risposta
TechVid sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 21
Tutti i Tempi: 260
