display not working anymore
I have this issue...my toothbrush io 9 display has stoped working but everything else working fine....i open it an and found water inside...this could burn the display? can it be fixed?
Questa è una buona domanda?
In my case, the battery leaked and damaged the circuit board. I had to repair one of the traces because it was corroded, and the display is working again. I also protected the board with electronics varnish. I replaced the battery and glued the damaged seal around the toothbrush neck.
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 47
Tutti i Tempi: 354
