Salta al contenuto principale
Il telefono-con-stilo al top di gamma della Samsung, successore del Note8, lanciato nell'agosto 2018. Ha uno schermo da 6,4" e fino a 512 GB di memoria interna.
Stuck in a BootLoop
I my phone keeps rebooting whenever i turn on the phone or even when i plug it in to charge. It just pops up the "Sansung Galaxy Note 9" logo and the switches off again repeatedly. sometimes, it even takes me to "Android Recovery Mode", and i have also tried factory reseting it, wiping the catche partiton and restarting it again but nothing works. What do i do?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Here’s what to do:
1. Your phone’s software might be messed up — you gotta reinstall the official system (called firmware) using a tool called Odin on your PC.
2. If that doesn’t work, your battery might be dying and causing the phone to freak out. Try swapping the battery.
3. If still nothing, some hardware inside your phone might be broken, and that’s a pain to fix without a pro.
So, first try flashing the system with Odin, then change the battery, and if it still sucks, get help or consider replacing the phone. Simple.
Punteggio 0
Aggiungi la tua risposta
Wisdom Simeon sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 31
Tutti i Tempi: 373
