Salta al contenuto principale
Un hard disk SATA da 3,5" e 320 GB prodotto da Western Digital.
Not allowing me to initialize
How to initialize the disk so that I can use it?
Questa è una buona domanda?
Punteggio 0
2 Commenti:
What is the system and OS you are trying to use?
da Condividi
My PC is Asus i5 4th Gen DDR3 so my HDD drive is showing error in my PC is " HDD is not initialized so how can I fix it??
da Condividi
Aggiungi un commento
1 Risposta
If your disk won’t initialize, first verify that the SATA and power connections are secure and that the drive is detected in the BIOS.
Then, in Windows Disk Management, right‑click the “Not Initialized” drive and choose to initialize it.
If initialization fails, try using DiskPart from Command Prompt to clean and re-partition the disk.
Also, check for any available firmware or driver updates from WD.
Could you please specify which operating system and system you are using, as the procedures might vary depending on the setup?
Punteggio 0
Aggiungi la tua risposta
Osfay Njenda sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 25
Tutti i Tempi: 349
