Salta al contenuto principale
Lo Xiaomi Redmi Note 12 4G/12 4G NFC è uno smartphone di fascia media di Xiaomi. Il Redmi Note 12 4G è stato annunciato e rilasciato il 30 marzo 2023. Questo telefono è dotato di un display con frequenza di aggiornamento fino a 120 Hz.
My Redmi note 12 Camera is done
My Redmi note 12 Camera doesn't work anymore, I tried everything, the repair shop said it's a hardware problem, and they can't get inside a Redmi, it was also Brand new, One day before the camera completely stopped working, I saw fog, inside the camera when I woke up,
I think there is a small plug that got loose, The flash is also Not working, So No camera and no flashlight. I just wanna go inside the phone, and connect that loose wire that I think is the problem, Anyone have an idea of what it might be ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
@sampiaimar this "I saw fog, inside the camera" means that you have had water in your camera. I just think you got more going on here then just a loose connector. You will also have to tell us which camera, since your phone has multiple.
Anyhow, use something like this video to get into your phone and to check things out.
Punteggio 0
Punteggio 0
Aggiungi la tua risposta
Sampi Aimar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 37
Tutti i Tempi: 574
