Salta al contenuto principale
{A1706 / EMC 3071}—Rilasciato a giugno 2017, questo MacBook Pro da 13" è dotato di processori Kaby Lake fino a 3,5 GHz Core i7 con Turbo Boost fino a 4,0 GHz.
How to fix/replace component underneath the key piece?
My E key has been missing for a while, but the component underneath still worked when pressed. Now, it’s no longer working. Can I replace just that break, or do I need to order a whole keyboard? TIA
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
You should be able to replace the scissor mechanism as well as the rubber bumper. Here is a source for the needed parts TheBookYard - MacBook Pro keyboard parts click on the image to dig into the different caps and other parts.
Punteggio 0
@valeriasan26150 here is the A1706 Keycap Replacement procedure. Take a look at page 2 for the explosion drawing on your keys. Although keycaps can be replaced, the butterfly and switch housing cannot. A damaged switch housing or butterfly requires replacement of the entire top case.
Punteggio 0
1 Commento:
Sorry OT I’ve replaced them using this part Keycap Mount and Dome - Alphanumeric
da
Aggiungi la tua risposta
V santi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 223
