Salta al contenuto principale
Riparazione di altoparlanti, autoradio, unità principali e lettori CD per auto o camion.
One side is not working.
The two bands on the driver's side are not working. All wires are connected and the bands are intact.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try swapping the L and R side speaker wires. If the sound switches sides, then you know the headunit/amp is the problem. If the sound stays on the same side, then you know the speakers or speaker wiring is the problem. If you can, run a new speaker wire from the headunit/amp to one of the speakers that's not working. That will help you troubleshoot if there's a wiring problem or a speaker problem. And of course double-check your balance and fader settings first!
Punteggio 0
Aggiungi la tua risposta
Jakk Maqq sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 12
Ultimi 30 giorni: 34
Tutti i Tempi: 376
