Salta al contenuto principale
La sesta generazione di Elantra è stata introdotta nel 2015 in Corea del Sud e lanciata sul mercato nordamericano nel 2016 per l'anno modello 2017. La Elantra 2015-2020 è stata venduta negli allestimenti SE, Limited Edition, Ultimate Edition, Sport e Value Edition.
Stalling ,Rattling, won't Restart
My 2019 Elantra Rattles then stalls at low RPM's.
It will not start again for about 15 minutes. I have also noticed the car may have some electrical issues as well .I have replaced the (MAP SENSOR,CAM SHAFT SENSOR, ALTERNATOR, serpentine belt and. Nothing has worked
.Anyone know what the problem is
Or how to fix this problem...???
Any help would be appreciated
Questa è una buona domanda?
Punteggio 0
1 Commento:
Have you used a scanner and read the OBD-II trouble codes? With an issue like yours I'd be surprised if there were't codes stored in the ECU. If you find one or more, they may point you in the direction of the problem rather than throwing random parts at it.
da
Aggiungi un commento
1 Risposta
Did you check oil level? Kia hyundai engines in that year range tend to have oil consumption issues, and a lack of lubricant will cause rattle, and stalling.
Punteggio 0
Aggiungi la tua risposta
Lancer sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 12
Tutti i Tempi: 202
