Salta al contenuto principale
Il Samsung Galaxy S8+ è la versione maggiorata del telefono al top di gamma Samsung. Lanciato nell'aprile 2017.
SIM card door locked
I can't open the SIM holder, it seems to be stuck; how can I remove it to take out the SIM?
I tried using a paper clip, but it doesn't click because it seems stuck.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
This one can be tricky because you dont want to force anything causing damage. Do you have access to a proper sim eject tool? I know a paper clip should and will work, however, I have had this very issue you are explaining. Worst case scenario is that you will need to remove the back and reset the sim eject pin. It's a black plastic pin near the sim tray that looks like a tiny cylinder.
Punteggio 1
Aggiungi la tua risposta
Piero Sabino sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 21
Tutti i Tempi: 204
