Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per lo smartphone Xiaomi Redmi Note 11 4G rilasciato il 1° dicembre 2021. Identificato dal numero di modello 2201117TG.
How to fix draining battery
Yes, so my battery sometimes drained so fast, like i just unplugged my phone from charging from 100%, after 20 minute, it's already 93%, and when i play game, it's drain fast, i was playing a game, and the battery is 14%, then its suddenly died,
Immagine
, i already check the battery health in the settings, its showing my battery draining so much, please, how to fix this.
Questa è una buona domanda?
Punteggio 0
1 Commento
My Xiaomi went from 100 to 60 in ten minutes without me using it, and shortly after it shut down, and started up right after, but as soon as I did something with it it shut down,And now it only charges up to 40% and shuts down as soon as you do anything with it, this happened after it had the battery changed by the phone rep,
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
@saad74735 you spend over 50% of the time playing games. Games are really hard on the power consumption of a cellphone. Also, if this is still your original battery, you do want to change the battery. It is kind of getting old. . After that, either decrease the time you play games or purchase a phone that is meant for gaming. There is no fix since this is normal
Punteggio 3
1 Commento:
thanks for the answer bro, appreciate.
da
Aggiungi la tua risposta
Saad sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 23
Ultimi 30 giorni: 65
Tutti i Tempi: 713
