Salta al contenuto principale
Guide di riparazione, supporto e informazioni per la risoluzione dei problemi per il MacBook Air 13 pollici di marzo 2024, dotato di SoC M3 di Apple. Rilasciato l'8 marzo 2024 e identificato dal numero di modello A3113.
Screen panel closing issue
I have an mba purchased in october of the last year. I have noticed today that when I close the screen, it will not remain closed at all. Is this normal or it is an issue and I need to get Apple service?
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Sounds like either the uppercase has warped a bit or the lid hinges are out of alignment.
Make sure you don’t have a snap-on shell as these have tabs to hold them on the gap between which is to narrow and all you do is crack you display. I only recommend skins which are more than enough for most.
Punteggio 1
22 Commenti:
I didn't use a shell and since I bought it, rarely I'v closed the lid, maybe at least 6/8 times. I'm a bit worryed
da
@ziobru Do you use a Keyboard protector or one of those webcam sliders?
da
I have a keyboard protector but it's very thin, I've tried to remove it, but the problem still remain
da
@ziobru - as your system is likely still under warranty I would head over to the Apple Store to see what they can do. But leave the keyboard protector at home.
da
I purchased it on the mediaworld online store and not into an Apple store. I don’t know if Apple will give me support directly. I sended today a mail to the support of the online store to understand if I can get warranty from them or I will need to go to an Apple store
da
Mostra 17 altri commenti
Aggiungi la tua risposta
B1P sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 378
