Salta al contenuto principale
Informazioni di riparazione e smontaggio per la serie B di mouse per computer Logitech.
Clicks are not registering
My mouse does not register clicks sometimes I have to apply to much force for a click to register
Questa è una buona domanda?
Punteggio 1
1 Commento
Which model of mouse do you have; there are several that fall under the "B" series and it is important to know the correct one.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
The switches inside that make up the mouse click function can get gummed up or fail. Since I don't know which mouse you have, all I can do is give you an example of the kind of thing you might have to do to either clean the switch or replace it. Here's a video for the B100 mouse showing how to open it up and lubricate the button switches with some WD-40.
Logitech B100 Switch Fix - Disassembly (click problem) - YouTube
That could be all that's wrong with your mouse, or it could be a failing switch or even a damaged finger mechanism. No way to tell without opening it up and taking a look. Replacing a switch would require some soldering if you feel comfortable doing that, but again we'd need to know your model number before we can make concrete suggestions.
Punteggio 3
1 Commento:
I think u r right because one time i tried to clean it by blowing air and they seem to work fine after that . Also I will work on ur solution so that it never occurs again . Thankyou :)
da
Aggiungi la tua risposta
Alber favahol sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 52
Ultimi 30 giorni: 181
Tutti i Tempi: 2,109
