Salta al contenuto principale
Il Lenovo Yoga 710-15ISK è un portatile di Lenovo Group Limited.
Replaced Battery not detected
Hi, i replace the battery of my lenovo laptop (with a battery from ifixit) because when i unplug the ac adapter it turns off. But the problem persists and the laptop wont detect the new battery.
I Tried a static discharge and disabling the battery in the device manager, but nothing seems to correct the issue.
what can i do?
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
There are multiple possibilities.
It is possible the new battery is defective, but unlikely since the exact issue was there with previous battery.
Even with a bad battery, the laptop would not go off instantly when the adapter connector was pulled out.
The most likely issue is internal to the laptop.
-The laptop battery connector.
-Another internal connection.
-The charging circuit on the motherboard - or it may have a separate PCB for that.
Punteggio 0
Aggiungi la tua risposta
Alejandro Coronas sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 285
