Flickering screen when powered on
How to stop a flickering screen?
Questa è una buona domanda?
Have you tried HP web site:
Several factors can cause your laptop screen to flicker:
Some applications may conflict with your system’s display settings, causing screen flickering. To determine if this is the case:
Outdated or corrupted display drivers are a common cause of screen flickering. Keeping your driver software up-to-date is crucial for optimal performance.
Physical damage or loose internal connections can cause screen flickering, especially if the issue occurs when you move your laptop screen. Examining the display cable can help determine if it needs to be replaced or serviced.
An incorrect ++refresh rate++ setting, particularly when using an external ++monitor++, can cause what appears to be screen flickering.
In some cases, hardware issues such as a failing ++graphics card++ or damaged screen can cause flickering. Additionally, a failing graphics driver can also cause flickering and should be checked.
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 7
Tutti i Tempi: 205
