USB-C Port Replacement
Is it possible to replace the usb-c port (not the cable)? The cable was pulled out aggressively at an angle that destroyed the corner of the inside of the port.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
More than likely, but the degree of difficulty is going to vary depending on the extent of the damage. Can you post a picture of the port on the board? You don't say that you're taken it apart yet.
da Condividi
Replacing a damaged internal usb port is not at all a simple procedure. If you disassemble the kb and take good photos of the damage, someone here may be able to advise what to do next. You should prepare yourself, this is likely not going to be repairable by non-professional. It may be cheaper to replace.
da Condividi
Aggiungi un commento
