Salta al contenuto principale
L'LG V60 ThinQ 5G, comunemente noto come LG V60, è un phablet Android prodotto da LG Electronics come parte della serie LG V. È stato annunciato nel febbraio 2020 ed è il successore dell'LG V50 ThinQ. Il 5 aprile 2021, LG ha annunciato la chiusura della sua divisione telefonia mobile e l'interruzione della produzione di tutti i dispositivi rimanenti. LG ha precisato che il telefono rimarrà disponibile fino a esaurimento delle scorte esistenti.
Right channel audio gone
The right channel audio does not work (bottom loudspeaker, right channel with wired earbuds. bluetooth is fine). I've had this issue for a while, and I decided I would replace the parts that (I thought) were defective. I replaced the bottom loudspeaker, the 3.5mm jack, and the antenna/sound board (I had also done other repairs during this such as replacing the bluetooth antenna, the battery, and the charging flex cable, all of those seem to be working fine now. It should also be noted that my flex cable replacement and the antenna/sound board replacement were ordered separately and did not arrive as one piece.) Even after doing all of that, there is still no audio coming from the right channel. I honestly don't know what to do now.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I have this problem too.
And after cleaning these two part with contact cleaner and cotton swab, both speaker and headphones works fine again.
Immagine
Immagine
However, after the fix, the phone can't connect to PC anymore. and charger with QC doesn't charge with full speed; it only reach full speed with PD charger. I guess I broke something during the clean.
Punteggio 0
Aggiungi la tua risposta
beaviszep sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 11
Tutti i Tempi: 176
